is it the clutch?
Old 04-03-2008, 01:57 PM
SLP4CamaroSS's Avatar
Default is it the clutch?
i go do a burn out and the pedel hit the floor and i have to raise it up wiht my foot. when i take off it does it to. it only happens when i do a burn out. someone told me the pressure plate is sticking becuase of the heat. is it the clutch or some people say it can be the master. i got a ls6 clutch/slave (both 10kmiles) stock master car has 90k miles. im goign to replace the clutch but just wanted to know if it was the clutch or somethign else thanks
ps got the drill mod also
Old 04-03-2008, 02:09 PM
thebart455's Avatar
sounds like it could be your master, my be your slave not working right also it could be sticking, or it could just be the pressure plate, but i would say its the master or slave ive never seen any of my friends pressure plates stick
Old 04-03-2008, 02:28 PM
its the updated slave it could go out in 10k miles?
Old 04-04-2008, 02:44 PM
thebart455's Avatar
yea mine did in like 7000 miles so i changed it with a 02 model slave. but mine dident stick to the floor it just got really and i mean really hard to push in and my clutch got smoked cause of it
Old 12-29-2010, 03:22 PM
mrobvious34's Avatar
my 02 did that, but only under pressure, it didnt do it driving normally but when i would launch it or do a burn out it would do the same thing. never figured it out. now in my 00 its starting to do it all the time just driving normaly even. and it pisses me off, i have to pull it up with my foot then pump it a few times
Old 12-29-2010, 04:20 PM
BIG_MIKE2005's Avatar
most likely its your master takin a dump. My pedal has been giving me fits for a while now & im ordering the Tick master to solve the problem forever. Not even gonna waste my time with the drill mod or any other master, so far every person i have seen using the Tick is extremely happy with it after & never has the pedal sticking issue again.
Quick Reply: is it the clutch?
