Which Slave ?
Old 04-06-2008, 08:28 AM
Blksilvr's Avatar
Default Which Slave ?
I have a 98 A4 TA that I put a LS2 in last year. I planning on changing to the M6. I want to use the LS7 clutch & LS2 flywheel. So the question is do I need a slave for the later 01-02 .... or do I need one for the LS2 engine ?
Thx
Richard
Old 04-06-2008, 08:47 PM
Blksilvr's Avatar
bump for TN
Old 04-07-2008, 11:44 AM
Sprayed 99's Avatar
Thx
Richard
i used a mcleod ms had better luck then the gm unit. as far as slaves go buy a new one from gm for 01-02. the older design had issues. as far as the ls7 clutch i'd go with a different one. alot of people havin issues. if u plan on makin more power later on i'd go with somethin a bit stronger. imo
Old 04-08-2008, 11:09 PM
white99's Avatar
The stock 01+ slave cylinder will do just fine.
Old 04-09-2008, 10:12 AM
thebart455's Avatar
+1 stock 01-02 slave will do just fine thats what i put in my car with the new clutch
