Spec 3+
Old 04-10-2008, 03:44 PM
Nasty275SS's Avatar
Default Spec 3+
As stated im thinkin bout buying the SPEC 3+ kit from LMPerformance and i just wanted to know, is there any thing else i absolutely NEED to buy, im on a budget!!! The car has 112,000 miles on er'? Any input will help.
Old 04-10-2008, 03:54 PM
zlover129's Avatar
I'm going to have to recommend against getting a spec, there quality has gone to **** here in the recent past. Seen too many go to **** first hand to ever get one.
Old 04-10-2008, 04:10 PM
Nasty275SS's Avatar
Yea you hear good pro and cons of every clutch ever made i just want one thats gonna last awhile that can withstand 500 hp or so on a 550 budget or so!!!
Old 04-10-2008, 05:09 PM
AzzBustin30th's Avatar
buy mine for cheaper.
Old 04-10-2008, 07:11 PM
Nasty275SS's Avatar
Nah man im kool, im just gonna buy it from a dealer for 8 bucks more just in case somethings wrong, i dunno im weird bout that ****, thankz tho.
Old 04-10-2008, 07:33 PM
SPLATT's Avatar
LS7 clutch?
Old 04-10-2008, 08:54 PM
Nasty275SS's Avatar
Yea man thats another one i was lookin at a good buy for your money i just heard it weighs a ton tho!!?
Old 04-10-2008, 08:59 PM
SPLATT's Avatar
nah, the LS2 Flywheel wieghs quite a bit, but you cant beat it for the price, and factor in drivability and power...that is one killer deal. I think it would be great for your setup, im making a shade over 500RWHP and im gonna take a crack at that clutch as well, Ive heard a couple bad things, but most the reviws for it are positive. i say give it a crack. the loss of a couple HP with a heavier flywheel wont be noticable
Old 04-10-2008, 10:02 PM
Nasty275SS's Avatar
yea man me n u both man we'll do it i dont care as long as it holds up. i dont go down to the track often so it should hold up just fine!!!
Old 04-11-2008, 03:11 PM
Nasty275SS's Avatar
I was just wondering tho, do they Rpm's drop real quick like SPEC's and others?
Old 04-12-2008, 10:21 AM
brad8266's Avatar
Buy a new slave cylinder while you are at it. Your flywheell will also need a resurfacing as well. Do not cheap out on resurfacing the flywheel, it needs to be done or the clutch will not last long.
Old 04-12-2008, 11:14 AM
nasty96's Avatar
anything but spec .. just pulled a tranny out 5 times cause they told me at spec nothing could be wrong with the clutch i replaced the master and slave cylinders , fluid dot 4, new flywheel , shimmed the slave , and finally took some measurements the pressure plate was off .090 that almost an 1/8 inch.. then had to pay shipping back to them and wait two weeks for them to check it and send me a new one.. they still said maybe something happened in shipping... yea right the steel grow in shipping ... haha
Old 04-12-2008, 08:25 PM
Nasty275SS's Avatar
Yea i dunno i hear lotz of good and bad bout this clutch and every other clutch made!!!
Old 04-12-2008, 09:16 PM
brad8266's Avatar
You will hear bad **** about every aftermarket clutch out there. Most of the problems come from a bad install and bad driving habits. Sometimes yeah of course there are manufactuer defects, but not most of the time.You cant slip any aftermarket high power clutch like you can a stocker and expect it to live as long as a stocker.
Old 04-13-2008, 01:09 AM
racecar's Avatar
You are right Brad
I have a Spec Stage 3, it doesn't slip, but chatters when you take off from a stop sign.
It is OK for racing, but crap for the street. They are way overpriced.
