tranny install question
I am fixing to install my new t-56 and was wondering if any one has ever installed one with out taking the bellhousing off of the motor? I was looking at it and that looked like the easiest way. I just really don't want to get into having to mess with the hydraulics ( bleeding them and what not after having to take **** apart) Let me know what you think would be the easiest way to go about it. BTW I have a new tranny and just have to swap them out. Thanks for your suggestions in advance!
1 Post
the key to having a long lasting and healthy tranny is the hydralics! if u dont want to bleed it or atleast do something about it, you wont be able to shift at high rpms or disaengage the clutch completly! the bleeding is not hard at all, and anyways when you are seating the new tranny in you must loosen the bleeder on the slave so it can compress and the tranny can seat into place! without doing that, things can be more difficult!
Well part of the reason I do not want to mess with the hydraulics is because everything was replaced a little over a 1000 miles ago. I understand that the key to a proper working tranny is the hydraulics, and that is why I do not want to mess with them! lol. I was just wandering if it were possible to swap them without unbolting the bellhousing from the motor.
Yes, you can. I just pulled, sent out, and then reinstalled my transmission from the car without removing the bellhousing (or the torque arm, for that matter ). As long as your clutch is working perfectly when you put it back together, you won't need to rebleed it, but removing the bellhousing itself has nothing to do with the hydraulics. The slave still has to come off the transmission, although I guess you could technically try to remove the tranny without disengaging the line from the master to the slave (if you drop the tranny, though, you'll probably rip it apart and screw a lot of stuff up).
Once it's all back together, just test the clutch with the dead stop disengagement test to make sure it's still working how it's supposed to and fully disengaging. If not, you'll probably have to rebleed the system.
Ok one more question.... I was talking to a guy today and he said something about the hydraulics on the slave being a quick disconnect style and that I wouldn't have to bleed the system after all...... Is this true? I have never been into one of these cars and am not toally sure how it all works and just kind of need a little push in the right direction with the whole thing. Is there a sticky anywhere with a how to? just kinda of wandering what all steps will need to be taken.
http://www.installuniversity.com/ins...sity/index.htm
