Whats the difference between early and newer T56 ?
Old 04-24-2008, 08:22 PM
fast_s10's Avatar
Default Whats the difference between early and newer T56 ?
I got a T56 from a 93 LT1 powered trans am and i was wondering what the difference was to a 98 and up T56 .I have a LQ4 i was installing and wanted to run a manual trans can anyone tell me whats different. Are the input and output shafts different? and what flywheel would i have to use .Thanks For any info .
Thanks John
Old 04-25-2008, 08:11 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Yes the input shaft is different and I think the LT T56s had different ratios
Old 04-25-2008, 08:18 AM
HoLLo's Avatar
LT1 had a pull-style clutch and the LS1 had a push-style clutch
Old 04-25-2008, 08:41 AM
BadGTho's Avatar
bingo.
Old 04-25-2008, 08:45 AM
jmm98LS1's Avatar
Thanks John
If you're putting it behind an LQ4, you need an LS1 version of the t56 (98-02). You'll be able to use a LS1 flywheel and clutch set. Like said above, the 93-97 t56's use a pull-style clutch. The input shaft, front plate and bellhousing are different as well.
Old 04-25-2008, 07:14 PM
fast_s10's Avatar
Thanks for all the info Thats what i was looking for
Quick Reply: Whats the difference between early and newer T56 ?
