Do I need a bellhousing?
Theres no guarantee that if you have it welded it will line back up. If its been distorted due to stress and you get it welded, you could have a hell of a time getting it back in.. I would check price on replacement to be safe.
Replacement is over $300.00 new. If you have the cash replace it with a reliable used or new part. Try checking around in the classifieds, it's not uncommon to seem them used.
If you get it welded, be sure to let anyone who does the work know that it can't be overheated and warped. Check for flatness on bell to block and bell to gear box surfaces before and after the work. If it is'nt flat before the work, you're probably best off replacing the bell. It doesn't take much to mess up the input to crank alignment and cause all kinds of clutch and bearing problems.
That sucks man, I would just buy a used one or a new one from Mcleod. If you weld the bell housing it may warp. Also its aluminum and if im not mistaken its tricky to weld aluminum.
I think the safe play is too find a suitable replacement. Either a good used piece or upgrade to an aftermarket unit. Any good fab shop should be able to TIG that one up just fine, but the warping/alignment issues other people have mentioned aren't worth the aggravation. Ideally, you would almost be better weld it on the car so it is stressed and the motor and tranny act as a "jig" of sorts to keep distortion to a minimum. Even with all that, I'd swap it out.
I sold my stock unit in excellent shape for $100 about a month ago, that's about the going price and they are out there.
Chris
Chris
