trans top hat replacement
Are you talking about the little plastic/delrin 'cup' that is in the shift rail and the ball of the shifter rides in??
If so, then yes, I change mine whenever I have the Pro 5.0 off.
It IS somewhat of a bitch to get that thing out (I used a good pair of needle nosed pliers), but it will come out.
Any of the internet GM parts dealers should have these in stock for < 1/2 of what most 'brick and mortar' dealers would charge.
Yeah, if I remember correctly, my 'tophat' was stuck in there pretty good as well the first time I tried to get it out.
I think I used a small slotted screwdriver to very carefully scrape out the remnants of whatever I could not get out with the needle nose pliers.
