T56 6spd output shaft oil seal
Old 05-03-2008, 08:18 AM
Dave1970's Avatar
Question T56 6spd output shaft oil seal
Can someone please provide the part number for the output shaft oil seal? I have check local parts houses in my area (e.g. Advance Auto, Autozone, & O'Reilly). Their database pulls up oil seals for the 5 spd transmission only. I found the attached seal off of one of their web sites. Is this the correct one? Which parts supplier chain would have the oil seal in stock? Thanks for the assistance. The seal I located on the web is from SKF and PN 14635. I haven't pulled the old one out of the car yet.
Old 05-03-2008, 08:43 AM
Black02SLPSS's Avatar
for autozone it is 5200 and that is 7.49, then there is 9613S and that one is 3.99. Im needing one too so there ya go. Went to their website.
Old 05-03-2008, 08:56 AM
SladeX's Avatar
just grab the GM one, the aftermarket pieces are too hard of a compound usually and don't fit perfectly at times. I've tried various ones only to have them start leaking again after a few months. Got fed up and spent on the OEM piece and was surprised how snugly and easily it was installed and how well it's held up over the past year and a half as opposed to those crap pieces I've tried.
Old 05-03-2008, 09:10 AM
Dave1970's Avatar
Thanks for the info. The autozones in my area don't list the part in their stores. I'll call the dealer next week for availability/price. Summit didn't even have a listing, odd.
Old 05-03-2008, 08:47 PM
jmd
jmd's Avatar
The 5spd seal works if you don't mind the circumcised look. If you want the foreskin, go to the dealer.
Old 05-05-2008, 10:12 AM
67rsss's Avatar
Amber sells them real reasonable, and will get you the right one.
Old 11-29-2008, 12:58 PM
ChiTownHustler's Avatar
National seal # 710426 available at most NAPA or CARQUEST stores, this is a booted seal just like OEM
Old 11-29-2008, 04:56 PM
massls1guy's Avatar
I recently installed that one in the picture. From the dealer it was expensive - over $50. I don't have my receipt but I believe this is it:
http://www.sdparts.com/product/10117848/SEALASM.aspx
Old 11-30-2008, 11:01 AM
thesource's Avatar
Its the same seal used in the TH350 , 4L60E and even on the Ford T5 and C4 .
Old 06-23-2009, 10:54 AM
WARP211's Avatar
GM Seal Part# 24232324
Old 07-27-2012, 02:59 PM
burbalanche's Avatar
Just picked one up hope it works
Old 11-08-2012, 07:51 AM
ed1le's Avatar
Which one did you get and how did it work?
To confirm, National seal # 710426 will work as well? All searches I've found list if for the Mustangs T-45's.
Quick Reply: T56 6spd output shaft oil seal
