Spec pressure plate + ram disc
Hi, i'm a broke student.. and recently my clutch went, i dropped my tranny yesterday, and my plan was to reuse my pressure plate, and flywheel (they look really good) with a ram stage 4 clutch disc that was given to me.. i dont have the $500 for a new clutch. my question is if the pressure plate and disc are compatible with each other?? like clearance wise and all..
it will work if you are in a pinch. RAM 4 is pretty aggressive disc so you may experience chatter.
Better to do entire new PP, disc and resurface flywheel.
You can also get a reman flywheel for $35 with your core from Kragen, etc. If the disc is new might want to do that.
its a used pressure plate, used flywheel (fidanza, so if i was to do anything i would just buy a new friction surface) and its a used friction disc. i just wanted to make sure it would clear.
