filling tans up
Old 05-04-2008, 02:12 PM
never2low's Avatar
Default filling tans up
Ok I hate to ask this, but can you fill the trans up through the shifter hole on the top. This is the fourth time I've had to fill the trans up and I'm looking for an easier way to fill it up.
Old 05-04-2008, 02:24 PM
LS1Tech Sponsor
Slowhawk's Avatar
I always fill it up through the shifter hole.
Old 05-04-2008, 02:35 PM
never2low's Avatar
Thanks. I have struggled with filling it up through the little hole on the side.
Old 05-04-2008, 08:51 PM
ghettocruiser's Avatar
I plan to drill and tap an NPT hole in my pro 5.0 shifter base so that I can fill without removing the shifter... I seal the shifter down pretty good with RTV and a gasket, so removing/replacing is kind of a pain. Not that I change my trans fluid THAT often. But putting a fill hole in that shifter base would be cake.
J.
Old 05-04-2008, 08:56 PM
Restricted User
socmguy's Avatar
Yeah, filling the side hole up can be a PITA but if you use a "lotion-style" oil pump, it's easy.
Old 05-04-2008, 09:30 PM
1fastTransAm's Avatar
Location: Chitown-Jax NC-Jax FL-Honolulu-OKC, OK-NOW New Orleans Area
u can use an empty mustard squirt bottle as well.. ensure its super clean.
good tip about the shifter hole as well.
