Spec stage 3+ clutch issues under spray !
Old 05-06-2008, 07:40 AM
Transamman25's Avatar
Default Spec stage 3+ clutch issues under spray !
The thing wont hold a 300 shot-- I Broke it in with 350 miles of city driving - replaced both clutch and flywheel at the same time .. Before i try again this weekend anything else i can do ?
Old 05-06-2008, 11:36 AM
LS1Tech Sponsor
Slowhawk's Avatar
Your probly past the torque limit of the clutch.
Old 05-06-2008, 12:29 PM
well i called spec and told them exactly what my set-up was .. they reccomend it -- i knew i shoulda went with a 5 .... Wonder what they would do for me now
Old 05-06-2008, 12:41 PM
slayerized6's Avatar
spec 3 holds 650 ft/lbs of torque at the crank. with a 300 shot, your probably over that limit. try toning it down to a 150 shot and keep increasing it until you find where it slips
Old 05-06-2008, 08:22 PM
the 3+ holds 800Lbs ... but i guess you make sense start dialing it back until it stops slipping
Old 05-06-2008, 08:29 PM
LS1Tech Sponsor
Slowhawk's Avatar
I found the limit at 700ft/lbs to the wheels.I'd probly limit it to 600ft/lbs.A 300 shot can hit the clutch hard with torque.You should be running a twin setup.
Old 05-07-2008, 08:13 AM
Well that really pisses me off as i told the guys exactly where i'd be and still got the wrong clutch ...
Old 05-07-2008, 12:34 PM
SPEC-01's Avatar
Trans...what kind of torque are you trying to make? Ultimately this will let me know more about what you need than anything else. Also, keep in mind that you have not completely finished the break-in. This is my suggestion, before you start cursing us for your issue, finish the break-in. Hopefully your decision to go all out on it before break-in was complete hasn't harmed the unit. If you want to you can pull the unit and post or email me some pics I will be happy to assess it for you. Let me know if you have any further questions. Thanks!
Quick Reply: Spec stage 3+ clutch issues under spray !
