Help, Reverse wont hold!
Old 05-11-2008, 01:13 AM
Green3spd's Avatar
Default Help, Reverse wont hold!
I have an Lt1 T56... I have to HOLD reverse in for it to work, sometimes I cant hold it good enough and it pops out and sounds nasty! It doesnt feel like its going all the way in...
I can push it to reverse, slow let off the clutch, and I can feel it fall farther in gear, and if I let go of it, it pops out once I start moving...
I have a Hurst Plus shifter, would that have anything to do with it?
Also, I do not have any other gear problems...
Old 05-11-2008, 03:17 PM
thesource's Avatar
You probably started out with a clutch issue and over time have had to push harder and harder to get the unit into reverse . This wears out the plastic fork inserts on the reverse gear fork and will start to eat into the fork itself . Once this takes place , you will need a rebuild and to replace worn parts .
Old 05-12-2008, 08:41 AM
Green3spd's Avatar
so would it be safe to drive it till I can?
Old 05-12-2008, 05:42 PM
thesource's Avatar
I wouldn't suggest it because you might end up tearing up the reverse gear syncro teeth but if you must , try to avoid using reverse as much as possible .
Old 05-12-2008, 10:27 PM
Green3spd's Avatar
I do aviod it as much as possible...
Old 05-13-2008, 06:59 AM
calhoon's Avatar
If its not staying in gear , chances are its damaged to the point of needing synchro & gear now as well as shift fork pads. You may also have to replace the fork itself( bent).
Old 05-13-2008, 08:22 AM
Green3spd's Avatar
Damn it... I bought a T56 because I was tired of breaking 4L60es..
Old 05-14-2008, 04:20 PM
Green3spd's Avatar
...bump
Old 05-18-2008, 07:20 PM
Green3spd's Avatar
Anybody else?
Old 05-19-2008, 12:21 AM
The Big Shuck LS1's Avatar
what he said
Old 05-19-2008, 05:08 AM
Black FormulaLs1's Avatar
get ahold of six speeds inc. or tick performance on here...they both build the T56 and do a damn good job of it ..
Quick Reply: Help, Reverse wont hold!
