Trans Grease?
Old 05-12-2008, 10:59 PM
Blksilvr's Avatar
Default Trans Grease?
Has anyone used any type of grease on the bearings or forks after a re build during re assembyl? If so what kind?
Old 05-13-2008, 06:56 AM
calhoon's Avatar
The best product is Trans Gel. It is actually a thick ATF-based product that disolves into the oil(ATF)when operated- is disappears. It is made just for this purpose. Avoid heavy axle greases as they can have a high wax /parafin content that can damage some blocker (synchro )rings. A light general purpose grease is all that is needed.
Old 05-13-2008, 11:40 AM
thesource's Avatar
I use a light bearing grease and it works fine . I have yet to have a single failure from using it .
