I know another one but is this trans fluid ok to use in my transmission?
Old 05-13-2008, 02:19 AM
Black99T\A's Avatar
Default I know another one but is this trans fluid ok to use in my transmission?
Is this transmission fluid ok to use in my transmission or do i need to drain it and use something else. Its the Dex\Mer Maxlife. On the side of my tranny there is a tag that says to use DEX 2. I know you guys recommend Sycromesh or Moble one, but will this stuff be ok?
Thanks
http://www.valvoline.com/pages/produ....asp?product=6
Old 05-13-2008, 06:50 AM
calhoon's Avatar
Its a Dexron/ Mercon-rated ATF so you should be OK.
Old 05-13-2008, 03:49 PM
black00TA's Avatar
well, it meets all the requirements
i used honda ATF in mine, and that worked the best for me.
similar to syncromesh, but better operation when cold.
Old 05-13-2008, 08:12 PM
Black99T\A's Avatar
ok guys, thanks alot for the replys. thats all I needed to know
