Can't decide on clutch
I've got a pretty much stock 98 Z28, just with some air intake upgrades and a 12 Bolt Moser rear end.
I need to drop my transmission to change the slave cylinder, so I might as well change the clutch too...
I want to retain the stock feel, but gain a little bit more grip
So which one to choose?
1. LS7
2. Spec Stage 2
3. Centerforce I
4. other
1. LS7
2. Spec Stage 2
3. Centerforce I
4. other
1. LS7
2. Spec Stage 2
3. Centerforce I
4. other
1. LS7
2. Spec Stage 2
3. Centerforce I
4. other
Sounds like the LS7 is the clutch for you. If you plan on a heads/cam set up then look into the Centerforce Dual Friction 12"
OK, seems pretty unanimous. LS7 it is.
I've hear I need to get a compatible new flywheel and change the pilot bearing. Any comments here?
I assume the clutch comes with a new throwout bearing.
Also, where can I buy the whole package? Anyone have good experience with a certain seller?
I've found that the GM Part numbers are
24238412 – LS7 Clutch
12571611 – LS7 Flywheel
14061685 – Pilot Bearing
Is that all I need?
Do I need to buy LS1 specific bolts? What about a throwout bearing? Or is that part of the slave cylinder?
Thanks
Is that all I need?
Thanks
