ls7 clutch installed
Old 05-19-2008, 12:27 PM
SLP Firehawk's Avatar
Default ls7 clutch installed
i installed my brand new ls7/ls2 clutch flywheel combo clutch and flywheel + new master cylinder all for 592 from gm dealer. along with that i also did the drill mod heat wrapped the line, new salve $80 from autozone and piliot bearing $14. to my surprise everything went smooth the old clutch came out smooth and went in great. i really recommend useing an old imput shaft for alignment made it a breeze. trans slid right in bolted everything up bleed the clutch and away i went. clutch engage ment is great feels like stock. i am still in the break in period and can't wait to see if it fixes my high rpm shifting problem " crosses fingers"
has anyone else that has had problems with shifting or the clutch hydrolics jambing up on you fixed the problem with all new components?
