Output shaft problem/maybe?
Old 06-07-2008, 10:25 PM
procsls6's Avatar
Default Output shaft problem/maybe?
I have a quick question. A few weeks ago I broke something in the trans or rear at the track. I got it towed and never touched it. I thought it was a output shaft because its a weak link. Since then I never touched it, last night I just went to start it up and I put it in gear and it moves about an inch. It will do it forward or backward. If it was the output shaft I would think it would not move at all. What could it be? Or I'am I wrong and it is the output shaft.
Old 06-08-2008, 04:53 PM
thesource's Avatar
Yeah if the car moves , then you did not break the output shaft .
Old 06-08-2008, 08:27 PM
danf1000's Avatar
Drive it more than an inch.
Old 06-08-2008, 08:59 PM
procsls6's Avatar
took it apart it the left side output shaft. Thanks
Old 06-10-2008, 08:53 AM
thesource's Avatar
Do what ?
Old 06-11-2008, 10:44 AM
85MikeTPI's Avatar
Originally Posted by thesource
Do what ?
I'm guessing this means the 5/6 extension shaft was broken? But then again thats on the RHS of the trans...
