Step by step on flushing/bleeding clutch fluid?
THIS IS THE METHOD I USE AND IT WORKS FAST, CLEAN, AND I THINK ITS THE EASIEST WAY....YOU CAN BUY THE PUMP ANYWHERE (AUTOZONE, KRAGEN, PEPBOYS) FOR ABOUT 30 BUCKS
http://www.performanceworks1.com/ls1...h_bleeding.htm
www.installuniversity.com
Do it exactly like they do, outside the car on a bench and you will be fine. Dont be scared of it, it does suck but its nothing but time.
This is Buschman's Clutch Bleed Method.
http://home.comcast.net/~buschman_00...utchbleed.html
The most important first step is too bench bleed the master.
Brand new GM master cylinders come pre bled allready so
bench bleeding is not neccessary.
