Theoretically speaking....another LT1 t56 thread, help me out
Old 06-17-2008, 10:21 PM
v6sb's Avatar
Default Theoretically speaking....another LT1 t56 thread, help me out
Ok, SO..... if the early th350s an 400 autos can be bolted to an ls1 with a flywheel spacer....then i still dont understand why an lt1 t56 could not be used on the lt1. Yes, the input shaft on the ls1 t56 is longer, but is this simply due to a deeper bellhousing that is required for a hydraulic throwout bearing????? since the lt1 t56 uses a slave cylinder and a clutch fork, is it simply a shallower bellhousing and shorter input shaft?
I have never seen the two side by side, so i cannot tell. i only have seen a few comparison photos on here, but never of the bellhousing profiles.
if an early sbc auto tranny fits on an ls1, then theoretically a lt1 bellhousing will too.... my question is, If a neutral balanced sb2 flywheel is used, then could it work?
Please dont just respond and tell me input shafts and bellhousings are different, i know.
Old 06-17-2008, 10:37 PM
Allvette's Avatar
You would have to use the LT1 style slave and fork as there is no way to mount an LS1 style slave.
Old 06-17-2008, 11:00 PM
v6sb's Avatar
that makes sense for sure. the only reason I am pursuing this a bit is because i have access to an lt1 t56. I know budget builds never stay as such, so thats not my worry, but it just seems that the ls1 t56s get snatched up so bloody fast... and I have nothing of ths ls1 variety available locally. anyways, i will keep you guys posted on my soon to be ls! /t56 shortbox chevy as it happens. i am in the collect the parts stage. if anyone has any comparision pictures of lt1/ls1 bellhousings from the topside... let me know.
Am I correct to believe that the ls! engines have a neutral balanced flywheel?
Old 06-19-2008, 07:04 AM
85MikeTPI's Avatar
You can buy a LS1 midplate and input shaft from a tremec dealer, but it'll run you close to $500 in parts. But you'd be able to convert the LT1 to a LS1 if you can't source the LS1 units around your area.
Old 06-19-2008, 08:00 AM
jmd
jmd's Avatar
Thumbs up
That's awesome to see my photos used. I took them for questions like these.
Quick Reply: Theoretically speaking....another LT1 t56 thread, help me out
