cts-v t56
They are M12 trans, same internals as the C5 Z06.
They use a remote shifter, that's linked to the center of the trans (by the skip shift solenoid), not the tailshaft. They also use a 3bolt flange and damper to hook to the driveshaft, not a splined yoke.
http://www.southernperformancesystems.com/dim_t56.html
I have one apart in my basement if you want/need any pics/measurements.
hth
mike
hth
mike
I don't think a mainshaft would be necessary; the splinage is different, but I presume you won't be digging into the internals. The shifter linkage out of an f-body would work, though you would need a tail section though. They are mildly superior, if it incurred much cost it would be better to have an f-bod t56 rebuilt. The superiority greatly depends on the year, what is it?
screwing the output flange on.
I'd be glad to post picks if anyone wants to see the CTS-V internals laid out next to the LS1s..
mike
