What clutch for 800+rwhp
TT-TECH Veteran
Textrailia Triple Hands down! I have one is both of the cars street driving is the best I have had and still allows me to power shift if when I want etc... Spec dual held good, but wasn't the best driving clutch I have had very off and on I am sure the different matrial they offer will make a difference though. Good luck!
Only one choice and that is a dual disk setup. There are quite a few reputable companies producing nice dual disk clutches for our rides. Spec, Mcleod,Ram,Zoom, and RPS to name a few. I personally went with a RPS carbon carbon dual disk clutch and all the surfaces are pure carbon and the whole idea behind that is carbon LOVES heat. The hotter the clutch gets the harder it bites. What more could you ask for. The driveablility is excellent drives just like a stock clutch just slightly heavier pedal feel. It will hold 1000 rwhp and 1000 rw TQ. The clutch does cost a pretty penny, try 2K, but a rebuild is only 400 dollars indefinitly and it comes with a bitchen flywheel. RPS is local to me here in Ca. All the above dual disk clutches work great and will hold your power level just fine with any rear tire setup you decide to run.
Th400 is great cluthc but suck the big one for street driving!!!! no engine braking in 1st or 2nd and must be stoped to shift into 1st... well aleast with mine fully built pro tree trans braked th400.. cant wait for my six speed....
