ignition cut out?
That's what she said...
You can use a Lingenfelter 2-step. You just set it to be active when the clutch isn't at the top. That way when you are launching, and you have the pedal down, you'll have a 2-step, and when you stab the pedal to shift, it cuts spark and the motor doesn't free-wheel between gears.
Lingenfelter has reported better shifting with this setup.
