Did i get the wrong Mobil 1 ATF ???
Old 07-10-2008, 07:32 PM
sidewayz28's Avatar
Default Did i get the wrong Mobil 1 ATF ???
I bought Mobil 1 Synthetic ATF multi-vehicle formula, Mercon V.... is that the bad stuff??
Old 07-10-2008, 07:55 PM
sidewayz28's Avatar
im running 2 quarts of Mobil 1 ATF synthetic and 2 quarts of GM syncromesh
sidewayz28's Avatar
yay or nay?
Old 07-13-2008, 12:23 AM
BigZee71's Avatar
If yours is a 01 or 02 then its the right stuff. Synchro mesh will ruin a 00 or earlier t56.
Old 07-13-2008, 12:30 AM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Question
UUHHHH---WHY. DO. YOU. SAY. THAT.???? '98-'02 T56 are the same. At least the F-BODYS are.
Old 07-13-2008, 10:06 AM
SladeX's Avatar
I ran synthetic, syncro, amsoil and just about all kinds of Dexron III Transmission fluid in my _98_ t-56
when I rebuilt it at 100k, the builder I had look at the parts said it looked like I babied the transmission.
Just keep with the maintenance. Even though I had the so called "paper" material blocker rings, my transmission was fine. Now that I've updated, it's still fine. I've actually been running Dexron VI for the past 10k now... so far so good, made around 20 track passes since then and still good, on top of WOT runs every now and then.
Quick Reply: Did i get the wrong Mobil 1 ATF ???
