Grinding Noise in all gears under heavy throttle
1 Post
I was crusinin around doing 30mph in 3rd, coming onto a circle... I decide to give it some gas, and I guess my transmission really didnt like it. I hear a grinding coming out of the trans, really dont feel much in the shifter, but i let off the gas. I ONLY hear it when I give it a certain amount of gas, like almost flooring it at that speed. It also did it in 5th gear doing about 55mph. I went to push it a little more than maybe 1/3rd throttle and i heard the same grind. but if i just beat the **** out of the car i hear nothing???!! wtf
My Formula only made a grinding noise under deceleration and was fine at full throttle. Sent the trans to Six Speeds Inc. and had to have them do a Stage 4 rebuild on it. I took out the cluster, the input shaft, and 4 gears. Hopefully that's not what your problem is, but it doesn't sound good.
1 Post
just did it in 2nd gear for me at about 28mph, i punched it and it grinded. im scared
i have a backup trans thats rebuilt with upgraded shift forks and such. i just need to save money for a clutch/flywheel/rear main/bearing/etc. setup. my poor trans
1 Post
ill check that out, but from what it sounds like it defenitly feels like grinding in the trans. but ill cross my fingers and hope that it really is a trans mount
