hydraulic leak question??????
For the past 2 months now my clutch has been sticking and has progressively gotten worse. Today before leaving my house it completely crapped out on me with no pressure what so ever, even when i pick it up.
I tried using the one man vac on the reservoir it just pulled up a continuous flow of bubbles that would not stop and would not hold pressure in the vac. Although it seems that i have a leak i see no fluid under the car. I took of the quick disconnect from the slave trying to isolate the problem. Once i did there were no more bubbles and the pressure held in the vac.
Although im pretty sure its the slave i just wanted to know if anyone has experienced this before i spend money in something thats not broken.
wrencher
Bleed it in the conventional method thru the bleeder.Try that first. search plenty of posts covering the subject. Check the master inside the car where the rod connects to the pedal. See if you have seepage coming from there if your losing fluid & cannot find it.
