Wont go into gear
Wont go into gear
So If I put the pedal to the ground and then try to start the car in gear the car moves...
If I let halfway off the pedal in gear the car will start, but when I push the pedal all the way in the car will stall.
I just replaced the clutch about 5 thousand miles ago.
Im so sick of this thing breaking!
Any ideas?
I replaced the slave cylinder when I did the clutch and used the shim it came with to.
Any ideas?
