which bearing
which bearing
I have a built t56 from 6speeds inc. my driveshaft recently messed up my seal and my bearing, i got the seal, what bearing do i need, some say viper but when i called advanced they said the part numbers where the same for viper and z28. tried calling them but they are closed on fridays at noon. where can i get this bearing at also
I think you are referring to the rear tail housing bushing . If so , unless you have a Viper spec converted T56 , you need a GM bushing which GM does not offer seperately . Apparently Rockland Gear sells a replacement bronze bushing for your application so you might want to give them a call Monday .
