To all the Spec haters
Old 08-06-2008, 07:39 PM
02SOMWS6's Avatar
Default To all the Spec haters
I have a old spec 3I in my car thats still holding strong. My clutch is about 4 years old , was broken in at the track when I did my burnout before my 6,700rpm clutch dump. The clutch is kind of due to fail by now. It slipped on a dyno pull recently but it has done that before and it was fine then so it should be fine now. I go to the track and run a 10.5@130mph with a 1.45 60ft. After that run the clutch proved to still hold. Next run I blew my ring and pinion apart in my spooled 12 bolt. I never thought my clutch would out hold my gears. I know there are lots of people that have had bad luck with there spec clutches and there has been a ton of spec sucks rants.I just wanted to post up a positive spec rant then a negative one. I know my clutch is due to go from all the abuse it takes but it's holding for now and when it does go I will buy another spec clutch
Old 08-06-2008, 07:59 PM
Kleeborp the Moderator™
MeentSS02's Avatar
...provided you still have feet to drive your car and operate said clutch.
Old 08-06-2008, 08:25 PM
02SOMWS6's Avatar
I have nothing but good things to say about my spec clutch.I have a engine protector plate and a scatter sheild . You know , the things that you should have in a high performance race car to protect yourself when your turning 7000rpm. I won't get in to the debate your trying to strike up. Just remember that lots of people have install errors but still point the finger at the manufacturer.
Old 08-06-2008, 09:51 PM
Red99TransAm's Avatar
Well I am happy to read something like this. I am not very happy with my current clutch and am seriously considering a spec for my next choice.
Old 08-06-2008, 10:44 PM
badbird's Avatar
ive had lots of good luck with my spec clutches.
even when i did have a problem with a clutch they had great customer service and took care of me much better than i had expected.
Old 08-06-2008, 11:13 PM
Tally TransAm's Avatar
im on my third spec and love every one of them. each of mine have lasted roughly 35k miles of completely absurd abuse and i couldnt be happier
next step is the billy badass dual plate one
Old 08-07-2008, 10:31 AM
SPEC-01's Avatar
Thanks for all the kind words and the appreciation of our products and service.
Old 08-07-2008, 10:40 AM
ls1 joe's Avatar
We use spec all of the time. We had it in our race car when it went 9.30's. It had 400 passes on it launching at 7000rpms, shifting at 8000+rpms and over 40K miles. I don't have a problem recommending there clutches to any of our customers.
Thanks,
Amber
Old 08-07-2008, 10:44 AM
crainholio's Avatar
It's entirely possible that some portion of the bad experiences with SPEC clutches are due to improper installation, given the varying skill levels (and ability to read a manual) of the do-it-yourselfers.
Old 08-07-2008, 10:45 AM
qwikz28's Avatar
maybe the 3i is golden because i've had mine on my car for a few years now and it works great. i don't drive mine as hard as you, but i do daily drive my car now. clutch has decent amount of miles on it. (~20k including over 10 track runs and 10 dyno pulls)
Old 08-07-2008, 10:49 AM
PewterScreaminMach's Avatar
We've had bad luck in the past with Spec clutches, but two weeks ago my brother decided to give the Spec 3 another shot, so we'll see how it goes. I'm currently very happy with my Tex, but I have no info on longevity yet, so we'll see what happens. I'm not totally opposed to going against Spec in the future if my Tex ends up crapping out on me, but I'm hoping it doesn't. The pedal feel between a Tex and a Spec is a no-brainer, but you pay for that.
Old 08-07-2008, 11:02 AM
wicked z28's Avatar
I daily drive my car with a spec 2 it sucked at first only because I couldnt power shift, but it shifted pefectly fine under normal driving conditions.But then I swapped out my master cylinder to a mcleod adjustable and now it power shifts as smooth as butter,I havent miss a powershift since. I love my spec clutch it so smooth and easy to drive.
Old 08-07-2008, 01:10 PM
LS1Tech Sponsor
Slowhawk's Avatar
Wish they still made the 3I. That was a great clutch.
Old 08-07-2008, 01:36 PM
98camaroLS1M6's Avatar
Is the 3I different than the 3+? I'm guessing it was just the regular stg 3 with the lightweight option?
I have the spec 3+ as do many others in my area and it definitely a great clutch for the money
Old 08-07-2008, 08:08 PM
02SOMWS6's Avatar
glad to see som positve spec post for once.
Old 08-07-2008, 09:09 PM
zach_ws6's Avatar
my spec 3 made a great name for itself in my old car. was very happy with it.
Old 08-07-2008, 10:49 PM
qwikz28's Avatar
hell yeah. i bought mine off you actually. it was a slammin deal. thanks by the way
Originally Posted by 98camaroLS1M6
Is the 3I different than the 3+? I'm guessing it was just the regular stg 3 with the lightweight option? I have the spec 3+ as do many others in my area and it definitely a great clutch for the money
i believe the 3i was the same as a regular 3 but with iron disks
Old 08-07-2008, 11:01 PM
SPEEDYws6's Avatar
Will be going to a V when my tex goes out.
Old 08-08-2008, 09:32 AM
SPEC-01's Avatar
Our 3I material was a predecessor to our stage 3+ which is an evolution of the material with a lower metallic content. Both utilized full-face disc designs and provide great drivability and durability but the 3+ is a bit more forgiving. Again, thanks for the kind words. Let me know if I may be of any further assistance!
Old 08-08-2008, 12:26 PM
thesource's Avatar
BINGO !!!! It doesn't help that the hydraulic systems on the F body flat out suck either . I've used several SPEC 2/3/4 clutch kits in our Mustangs and when properly adjusted with a good driver , they last . Biggest problem is they are hell on transmissions . When the clutch does not slip , something has to give and usually its the T5 behind it . I have even destroyed a Tremec 3550 with a SPEC 3+ in my car a couple of years ago .
