Vibrations
Old 08-12-2008, 12:33 PM
c5_ls1_6spd's Avatar
Default Vibrations
Car (C5 6spd) is at a standstill (0mph):
I rev it in neutral with the clutch out (only pedal im touching is the gas) and at around 2000rpm, it starts vibrating (the shifter and the car itself). What all is turning as I rev?
I rev it in neutral with the clutch in (clutch pedal is pressed in) and it's a smooth clean rev no vibration.
Old 08-12-2008, 12:57 PM
toneloc60's Avatar
The input shaft and clutch itself is turning. That's the only difference.
May have lost a spring or weight in the clutch.
Old 08-12-2008, 01:20 PM
When is what turning?
Old 08-12-2008, 02:03 PM
toneloc60's Avatar
the input shaft and the clutch are turning no matter what when you don't have your foot on the clutch pedal. When you press it in, they stop turning.
Another thing that could be the problem would be the input shaft bearings could have taken a crap.
Old 08-12-2008, 02:37 PM
T56 rebuilds just told me the input and outshaft spin when the car is in gear.
wouldn't a worn bearing make somekind of noise? I'm not getting any noises of anykind, just vibration.
Old 08-12-2008, 03:58 PM
How can I tell if it's the input shaft without pulling the tranny?
