WONT shift..need help
Old 08-15-2008, 12:02 PM
camSSaro's Avatar
Default WONT shift..need help
I apologize if there is a sticky about this but I installed the spec stage 3 clutch in close to a year ago without annykind of drill mod to the slave and it has progressively gotten to where it will not shift into any gear. Is the drill mod or a different slave a must when going with the spec stage 3? not to be confused with the 3+. Does anyone have any suggestions? definately need help guys. just gimped it home going from 1st to sixth! has always been that bad
Old 08-16-2008, 12:42 AM
wrencher
wrencher's Avatar
What is the pedal like? Spongy? Does it release/engage close to the floor/bottom of the pedal then?
Old 08-16-2008, 12:57 AM
streetsurfinseth's Avatar
if the pedal is sticking to the floor then you need a master cylinder. you can get a ram off of ws6store.com for like 150. so that a lot better than having to pull the tranny. if the pedal is just spongy then i dunno, mine is the same was with a spec 3.
