grinding?
It's not your clutch. I was told that it was a bent shift fork that caused the problem with mine. That or a synchro, no ****** clue, but it isnt your clutch.
The 1-2 fork does not bend( have you looked at one?) A bad clutch will destroy all the synchronizers. If have been driving with a knwon bad/ poorly releasing clutch, plan on a new trans too when you get around to fixing the clutch.
