the drill mod didnt fix it
I just did the drill mod a few days ago. When I did, I emptied the clutch reservoir & the fluid was black. So, I changed the fluid & did a good bleed. The clutch pedal was just about the same as before, a good solid feel to it. I went to the track to test it out today, it did it again. Sometimes it will shift ok, sometimes it wont shift at all. When it wouldnt shift, I noticed the pedal felt kinda limp. Not to the floor but just softer. Its possible I need to upgrade to the 01-02 hydraulics & or upgrade my clutch. Its one or the other for sure, so I might as well do both & be done with it. BTW, how often do you guys change your clutch fluid? A guy at the track with his 98 Trans Am says he changes his every week. That sounds a little too frequent.
same here man, did the drill mod, big pain in the rear, and it didn't fix my problem. Ive got 125,000 on the original clutch and hydroics, so probably just need to change all of it
It' s not the hydraulics ...... It's the pressure plate. I never bleed mine and went through the master/hydraulic release bearing/ bleed flog. Anything you do in that region is temorary at best. The guy that bleeds his every week.... I definetly would'nt listen to him.
I dont know I had the same problem on hard acceleration it wouldnt go into gear by 2-3 shift or sometimes by 1-2 shift and the pedal was soft I did the drill mod and changed the master at the same time and it worked. I also have a cheap clutch setup so if it was that I would have known and I have about 450 rwhp I would change the master before pulling the tranny
I have the same problem. Especially after the Textralia clutch was installed. Since then I've replaced the master and slave...did the drill mod. The pedal seemed easier for a couple of days, but now it acts up on start up and when it's cold outside.
