What do I need to do?
Apologies if this is the same ole question, but I dont believe I have read about this in my searches...
Today I was driving my 2001 TA 6-speed that I just recently picked up. THe clutch was doing fine for about 10 minutes, then when I got to my destination, I was going to back into a parking spot. Put the car in reverse, went in fine, but then the clutch would not come up, and I couldnt get the car out of reverse. Then the car cut off with my foot completely pressing the pedal to the floor. On the way home it was doing the same thing, but in 1st gear.
Anybody got any ideas whats wrong?
wrencher
You have hydraulic issues. Check the fluid, see if it is leaking. Check out the sticky threads at the top of this section as well.
You might be able to bleed it out to get you by as well.
