Help WIth tranny part!! Pics inside
The synchro teeth on it are engaged in 4th (direct lock between input and output, 1:1), but the gear on it actually turns the countershaft that directly affects the ratios of gears 1 through 3. It is in constant mesh with the countershaft, which is also coupled to the extension shaft with 5/6/R gears.
A new input shaft is one part, but it will not have the large bearing, NOR the bearing race inside the cup where the mainshaft rides.
