Problem with my clutch
I have a ’02 Trans Am. I am having a problem with my third shift. Its fine the first 2 gears but when I throw the clutch in to shift to third, the pedal goes right to the floor and it wont go into gear. If I pump the clutch 2 or 3 times then it will go into gear. Under city driving its fine, it only occurs when I am racing. I have tried to bleed the system and it didn’t change anything. Could the fluid be boiling in the line (creating air bubbles) since the steel braded line runs right over top of my long tubes? Would there be an issue in changing to DOT4 brake fluid? Any kind of help would be appreciated.
You also risk injuring the tranny internals if you try to force it into gear at high RPMs if it won't shift correctly. Just a heads up.
A lot of people try to say it's the slave, or needs to be bled, or it's strictly a hydraulic thing and the stocker is fine, but most people that attempt to remedy it in this way wind up not fixing anything but every person I've seen with this problem who replaces the stock clutch (including myself when I first got the car and also close friends) solved the issue.
Yes your right. Stock clutch but not a stock car. I’m putting 465 to the wheels. I have only had the car for 5 months and it has been fine up until last week. I had plans to do the clutch but wanted to wait to make it a winter project. What kind of clutch do you suggest? Should I use the stock flywheel? (just reface it)
