Master Cylinder question
Old 09-06-2008, 04:17 PM
grub-2001z28's Avatar
Default Master Cylinder question
I've been going step by step through my stuck pedal woes, and I'm in need of some advice on the master.
I flushed and bled the lines, no improvement at all, so the next thing I'm looking at is the master. I recall reading somewhere, not sure where, that if you pop the quick disconnect from the slave that the pedal would be very firm. This is the case for me. I am not able to depress the clutch at all with the line to the slave disconnected. This shocked me as I was nearly convinced it was the master and I was expecting the pedal to be soft.
Does this mean that my master is likely not faulty at all and the slave is the culprit?
Thanks
Old 09-07-2008, 01:14 AM
wrencher
wrencher's Avatar
I have seen that test not to be so accurate sometimes.
When the master is moving down the bore & displacing fluid it can act differently is the only thing I can surmise.
Old 09-07-2008, 07:02 AM
Interesting. Are there any tests to see if the master is faulty or is it pretty much just replace it and see if that helped?
Old 09-07-2008, 10:50 PM
wrencher
wrencher's Avatar
Pretty much rule of thumb, if the slave isn't leaking & you cannot build pressure replace the master.
Quick Reply: Master Cylinder question
