ws6store short stick
I have had the short stick on my car for about a month now, but there seems to be a slight "issue" with it, and only noticed it when I put that on there, and never noticed it the stock hurst shifter. Whenever I am trying to downshift, say going into 2nd at 50 mph, slowing for a turn, you can hear slight, quiet grinding. With no music on, you can hear it. I don't know if it my syncros, or from the shifter. Going into 1st at around 30mph is where you can really hear it, but if I wait till about 10-15 mph to put it into gear, it slides in a lot easier and will hardly grind. Is this directly related to my short stick, or is it coming from back syncros in the transmission? Thanks.
wrencher
Sounds like your trans to me.
If your trying to hit those gears at that speed downshifting with the motor at or near idle I expect it to make noise.
Depends on how's it's geared (rear & tire size) but you need to rev match to get smooth down shifts @ higher speeds for a low gear.
A stock m-6 is doing 3600rpm in 1st @ 30mph, 4000rpm in 2nd @ 50 mph for example.
You try to shift those at those speeds at or near idle your giving the trans a workout.
I'm pretty sure it's just that the stocker was better "noise sealed" lol.
I put a pro 5.0 shifter on a t56 a while back, with the short stick. You hear every noise the tranny makes. Nothing is wrong, you just don't have a big rubber bushing to cancel out any noise anymore. You're new shortstick doubles as a pitch fork for synchro grinding!
Enjoy!
Enjoy!
So no issues then? Wrencher, I am running 4.10s, but the grinding is making noises with my clutch completly depressed and going into gears. Not like it is shooting up revs, and rev matching, I mean having the cluch all the way pressed in, going into any gears except if I'm slowing down to a very low roll makes those noises. If z28 is right, then its cool and whatever. I'm just worried that I MIGHT be causing damage to my trans...right now as a broke college student, money for a new t-56 is pretty iffy.
wrencher
I wasn't sure if you where trying to jamb gears here
It could potentially be a future problem, but it's real hard to detemain that not seeing it first hand.
But expect more noise with the new shifter, the farther from stock you get..... lol
Ok then, thanks. I have been adjusting my driving style so I wont hear or notice the grinding noise. z28, it is not a whinning noise, it is a slight grinding type noise. Not like gears grinding, hard to explain. I think it is just shifter noise. Thanks guys.
