help!!! clutch problem
i just picked up an 98 z28 with 136k mi and im having a problem with the clutch. the car has all the bolt ons i can think of and an ls6 clutch. when the car gets over 5000 rpms the clutch feels like it just gives out. could this just be clutch fluid or do u think im going to need a new clutch.
ps. the car has an built 8.8 rear end with 4.10s and some slicks im thinking im going to need a new clutch some time soon.
On a side note, do you have any pics of that 8.8?
kind of sounds like you need to do the DRILL MOD, you can thank GM for having small hydraulic lines which limits fluid flow at high rpms which is why your pedal feels weird above 5000.
http://web.camaross.com/forums/showthread.php?t=434580
pics of the rearend. from ben.
the clutch still goes in and can shift. it just feels like im just reving the car.
i believe it is the clutch fluid. what clutch fluid would u recomend.
The drill mod consists of removing the clutch master & drilling out the restriction in the steel braided line. Once you remove the master, remove the roll pin & theres a restriction built into the line on the master cylinder side of the line. A 7/64 drill bit is what you'll need. Do a search & you will find out all you need to know about it. I highly recommend doing it, even though it may not fix the problem you are having. Be careful not to break the bit off in the line. I didnt have any problems but others have. I would think if you use a good quality drill bit you shouldnt have any problems.
hey i changed the clutch fluid to dot4 and it feels a lil better i still have the same problem. my friend thinks its the master cylinder, and i still have a brand new ls1 master cylinder to replace it with. what do u guys think i should do.
