drain trans fluid good idea?
Banging some gears
putting a new clutch in soon and i was wondering if it would be a good idea to drain the fluid that is in the trans now.... the car has 85k+ miles on it and has never been into as far as i know. was thinking i should drain it and refill it with the GM syncro-mesh fluid. anyone have any input.. if i do decide to do so, how many quarts does the stock T56 hold?
Thanks in advance,
Daniel
Thanks in advance,
Daniel
Kleeborp the Moderator™
I think according to the service manual, the T-56 fluid is a lifetime fluid. I don't buy that though...so draining the old and refilling it with new is a good idea IMO. Capacity is 4 quarts, and as long as the fluid is Dex III compatible, it should be fine. There is a lot of debate on synthetics vs. non, and there was a HUGE thread in this section about that very topic. If you do a quick search, I'm sure you'll come across it...you can't miss it.
1 Post
since you have a 2001+ car, syncromesh is safe in that tranny. 4 quarts will do it. do yourself a favor and buy the penzoil brand from your parts store instead of from the stealership. it is approved for the GM spec number.
taking out the transmission is a bit of a pain due to its awkward shape. Every bit of weight helps when removing that thing and lining it up to reinstall.
Wow lifetime huh? I've changed my fluid at least 4 times in the past 2 years. Just part of my maintenance schedule...
Banging some gears
wed is the day... i got a deal on some GM syncromesh (got a buddy that works in parts dept. at the dealership) so i went that route... thanks for the input guys can't wait to spray this hoss with a clutch that will hold!!
