upgrading t56
upgrading t56
I just recently broke my t56 transmission. When I pulled my trans out I found that I twisted the input shaft in half. I am only putting 420 HP to the wheels. I have previously tore the trans apart and put in a steel 3-4 shift fork and Carbon Fiber blocker rings in. While it is apart I am planning on puting bronze fork pads and billet keys in it. Do I need to do the viper input shaft and mainshaft conversion since I have alrady broke the input shaft once or was it just worn out from having 120K on it? And are there any other upgrades that u guys would recommend?
So is the LS1 T56's input/main shafts made of a different material than the Viper's?
As far as I knew, the only thing a Viper trans had going for it was the different gearing
Breaking a 26T input is not common at torque levels well above yours. What condition was the pilot bearing? Are you using a std bell? Are the dowells there? Something "helped" break this and you should look for it/ solve it before you throw anothe trans at it.
Later Vipers ( 04-on)have a sigle piece cluster gear and they do have different input material (9310 over 4615) besides gear cuttings.
I am using a stock bellhousing and the line up dowels are still there yes. And yea i just got off the phone with Amber from six speeds inc and she said to do away with the roller pilot bearing and use a bronze pilot bearing. And yes I agree with you I still need to do investigate everything before I fix everything and later run into the same problem.
the trans still goes through 1-6 and reverse perfectly fine. And no I havnt opened the trans up yet but will be soon. Here are a few pics of the input shaft on the trans side. I havnt pulled the bellhousing, and clutch out yet.
The pics aren't very well focused on the input shaft damage, but it doesn't look like a twisting tear, but a shearing break.
Who did the recent rebuild of the trans? Something doesn't seem right, either with the pilot support or the end-play of the input shaft to cause it to have a shearing force on the input shaft??
