Clutch problems
Clutch problems
I was racing my car in the 1/4 this past weekend and started having problems with shifting...it seems that when I hit the peddle hard and shift it does nothing...feels like I'm power shifting the car through the gears...when i hit 2nd its just like a power shift, when shifting to 3rd its very hard to get it in the actual gear and when shifting to 4th its the same, with a some grinding...
Regular driving is unchanged though..whats going on here?
The cars is a 2000 ss m6, mid size cam...bolt-ons...4'11s
Have you done the drill mod? This is a common symptom of cars that are having issues with fluid transfer (which limits the amount of fluid that can be passed between the slave and master via the feed line). Check it out and let us know what you find. Thanks!
