LSX Winter Dyno Tuning Specials Starting @ $250
Hey All,
Now that things are getting up and running at the new shop, I thought I would offer the locals some Winter Specials to help folks out. These specials will run initally to the end of February.
On the LSx tuning side, I am going to offer my normal Base Dyno Tune for bolt-on cars at $250, normally priced at $350. This pertains to LS powered vehicles using factory ECM's and are modified with external bolt on's only.
I can also offer my mild cam and heads & cam combo tuning for $300, and that is normally $395.
For folks that have aggressive cam or heads & cam packages as well as FAST or fabricated intake setups, it will run $350 and is normally $450.
Large cubic inch setup will vary depending on the combination, but most will run that same as the aggressive cam or heads & cam tuning.
True SD tunes would not be suspect to this special due to the time requirements. An SD tune can range from $500-750 depending on the combination.
All tuning includes base dyno run, all necessary dyno time, widebad AF readings as well as street verification of the tune.
For info please feel free to call me at 407-616-2518 or e-mail me at thevettedr@aol.com
I will also be doing some install specials so feel free to ask if you want something done. I know a lot of folks do not like to take the cars out during this time of year, but this is actually the best time of year to get your mods done in prep for the upcoming good weather.
Thanks.
Mike Norris
Thanks.
Mike Norris
Hi Ted,
I apologize as I missed you question here. The normal pricing on my website is $1895 for the dual spring installed and tuned package and I will be running a special soon
For the special pricing, most LS powered cars it will be $1595 for a base single spring package installed and tuned and $1749 for the base dual spring package installed and tuned.
Feel free to PM me here, e-mail me at thevettedr@aol.com or call me at 407-616-2518 and I can go over everything with you.
Thanks
Mike Norris
Thanks
Mike Norris
Hi Mike,
Hope you are enjoying our lovely Indiana winter. How late are you in your shop in the eve. and are you in on Saturdays? I'd like to stop by some time and talk about a cam install. Thanks
GO COLTS
GO COLTS
My hours here kind of vary due to me being a one man show. There are times when I need to take care of my son and others when I need to run and get parts and such. I also can be gone 3-4 days at a time to travel on some of my tuning trips to different areas.
I always suggest trying to catch me on the phone to see if I am here just to not waste a trip. With that said you can stop by pretty much anytime to say hey. Normally, my hours are 8:30 to 5 Mon thru Fri and Saturday by appointment only. I have been here as early as 7 and leave as late as 8 as it all depends on what is needed. I try to be pretty flexible.
So just let me know and definitely GO COLTS!!!! I was a fan way back when I lived here before and they were very bad (3-13).
Mike Norris
Mike Norris
