Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
where is the best place to get a tune up?
Old 08-07-2010, 12:35 AM
trans/am man's Avatar
Default where is the best place to get a tune up?
i live in Livonia Michigan and want to know where the best place to get a tune up is for a pretty fair price and i really want to bring back alot of the lost horse power that i have lost
Old 08-09-2010, 05:11 PM
conor.davis's Avatar
have you given any thought to doing it yourself?
Is it an ls1 TA? If so, its all really straight forward...
plugs, wires, air filter, fuel filter, oil change if you need it...
Old 08-09-2010, 07:48 PM
FormulaWs666's Avatar
You shouldn't be allowed to drive your car if you don't do the work yourself...
Old 08-17-2010, 10:27 PM
im only 17 and im trying to learn but dont wanna mess anything up so i rather get it done for now and is it simple to do it your self and yes i have a 98 ta A4
Old 08-18-2010, 07:40 PM
ds98formula's Avatar
Well if you where closer to me I would help you out
Old 08-18-2010, 08:35 PM
1_bad_TA's Avatar
Doing plugs/wires/fuel filter/oil change is cake. Use the German Castrol oil and K&N filter. Filter #hp2006 should be the larger capacity one. You can't really **** up doing plugs and wires unless your legally blind or cross thread a plug. Make sure to put a small amount of anitsieze on the threads of the plugs. Fuel filter is the quick disconnect type. You can pick up the little tools from any parts store pretty much to do it. They go around the fuel line and you push it into the filter. Lines should slide right out. If you can't change an air filter, you shouldn't be allowed to drive and have your man card revoked.
Old 08-18-2010, 08:42 PM
s346k's Avatar
your garage..
Quick Reply: where is the best place to get a tune up?
