Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
Edgewater Sports Park
Old 09-30-2011, 04:00 AM
WhitePhoenix99's Avatar
Default Edgewater Sports Park
I'm planning on going to Edgewater Sports Park in Cleves, Ohio today.. I've never ran there before so not sure what to expect. I'm particularly interested in how strict they are with tech..
It says on their website that if you run nitrous oxide you must have a fire extinguisher mounted in the car, is this true? Is this an NHRA rule? The normal track I go to does not require this.
If anybody can give me a heads up it would be appreciated
Old 09-30-2011, 09:23 AM
blue99fbody's Avatar
How fast is your car? They are usually strict on cage and harness rules and on having a comp licenses if u need it. I've never been checked for a fire exthingisher they also are strict on having a ds loop when running slicks. They usually don't make u open the hood or care about a kill switch or small ****. But I can't say forsure on everything bc I go there often and they don't look at anything on my car anymore.
Old 09-30-2011, 09:38 AM
I'm only going to be running a 100 shot. It's a cam/bolt-on LT1. I will be running 26x11.50x15 bias ply ET streets, but they aren't full slicks technically. I'm not sure how fast it will be.. probably mid-high 11's on the nitrous.
I don't have a cage or a DS safety loop
Old 09-30-2011, 09:41 AM
Or tri state is 15 min from there and they don't give a **** about anything. They run sat 12-5 I believe
Old 09-30-2011, 10:03 AM
Well I might give that a try then so I don't waste a trip over there. Thanks for the info man
Old 09-30-2011, 10:09 AM
Plus its cold, windy, and spitting rain here now
Old 10-04-2011, 09:01 PM
2manytoyz's Avatar
wheres tristate at? is it a 1/4 or 1/8
Old 10-06-2011, 05:50 AM
Its in Ross and 1/4 mile just a small hole in the wall track
http://www.tristatedragway.com/
