possible part out/back to stock/sell as roller/ fuck it just look
possible part out/back to stock/sell as roller/ **** it just look
Wasn't sure if this should go in the midwest classifieds or not. Just bought another WS6 vert and I can't have 2. Debating on whether or not to swap all the stock stuff over from the blue one or sell it as is. The new one I bought is a 99 and my other is a 98 so if I were to swap engine stuff both would need a retune. In all honesty I would prefer to sell it as a whole or sell it in large chunks. I am located in Milwaukee so if anyone does have any interest feel free to pm me and we can meet up or something if need be.
Here's the info on the car I am looking to get rid of.
It has 72k miles on it. Most of the modifications I put on around 60k. I also have a set of oem WS6 wheels that I can swap for the C5 DD wheels if someone wouldn't want those.
The car was originally white and the PO painted it silver. It was repainted oem silver but when the metallic red racing stripes were put on it, the clear coat had a small amount of red flake put in it.
As far as things that I can thing of that are the cons are:
-power door locks don't work (I am assuming this is a bcm issue)
-the rear window is separated from the top of the top.
-The drivers seat has a tan trim piece that goes over the power seat adjuster instead of the black.
-the radio isn't mounted. Never really bothered me because I rarely use it so I just ziptied it to the bezel and it works perfect for me.
-Camber is slightly off on the front tires so the inside of the tires are fairly worn down.
Only things I would be keeping would be my superhawk hood (which would be replaced by a silver flat TA hood), the shift **** that I made and maybe the billet cap set. I also might swap the shock spring combo over to my blue one and put the eibach KYB set on the silver one.
Here's the mods list that I can think of. There may be a few more little things:
Engine:
Patriot Stage 2 Heads
Texas Speed hardened pushrods
Comp Dual valve springs
Comp 273LR cam
Ported ls6 intake
Billet Fuel Rails
Ported MAF ends
Ported TB
SLP Lid
Poly Motor Mounts
Norris Catch Can
Chris 1313 Ram Air
Custom Coil Reloation
Pacesetter longtube headers
Custom 3" True Dual Dumped Exhaust
Transmission and rear end:
Tick Stage 2 T56 Transmisson
Tick Adjustable Master Cylinder
Spec Stage 3+ Clutch
MGW shifter
Custom Machined Shift ****
Stock 10bolt with 3.23 gears (Blew up the rear with 4.56s )
Suspension:
BMR Front and Rear swaybars
BMR adjustable panhard bar
BMR tubular lower control arms
Sphoon tubular upper A arms
Koni Single adjustable shocks and struts (Fronts set on lower perch)
BMR lowering Springs with Heater Hose mod on rear
BMR strut tower bar
Drilled and slotted rotors with carbon ceramic pads
ABS Delete
Wheels:
C5 Deep Dish Machined face replicas
18x9.5 in the front with 275/35R18 Toyo R888s
18x10.5 in the rear with 315/30R18 Toyo R888s
15mm rear spacers
Rolled rear fenders
Interior:
Red gauge lights
All other interior lights white LEDs
Sunvisor delete
HVAC Delete
dual pillar pod with innovate MTX-L wideband (PO just screwed a pod to the pillar)
Alpine type R speakers in all 4 spots with tweeters in front
Other Appearance:
Shaved, smoothed, and painted engine bay
Custom Retro style taillights
Engine Billet cap set
Powdercoated battery cover
Trans AM badges removed
LCM truck housing headlights high and lows
6k HID in lows and fogs
LED switchback turn signals
Clear front markers
CETA mod
Here's a bunch of pics
I can take picture of anything else if anyone wants any.
Engine:
Comp 273LR cam
Ported ls6 intake
Billet Fuel Rails
Ported MAF ends
Ported TB
SLP Lid
Poly Motor Mounts
Norris Catch Can
Chris 1313 Ram Air
MGW shifter
Suspension:
BMR strut tower bar
ABS Delete
Wheels:
15mm rear spacers
Rolled rear fenders
Interior:
Red gauge lights
Sunvisor delete
HVAC Delete
Other Appearance:
Clear front markers
CETA mod
