Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
IL emissions
Old 04-15-2015, 03:30 PM
2QuikTA's Avatar
Default IL emissions
Can you have any dash lights on or is that an immediate fail? After the rear end swap I have intermittent brake and abs lights. While I'm figuring out the fix, I'd like to be able to renew the tags.
Old 04-15-2015, 06:05 PM
SimZ28's Avatar
Nope, they cant fail you for brake and abs lights. Just for the check engine light
Old 04-15-2015, 11:10 PM
99FBODY's Avatar
I went through with my abs and tcs light on. Had no problems at all.
Old 04-18-2015, 10:52 AM
BlackCowl's Avatar
I have my abs and brake light on too, along with my low washer fluid since it isn't hooked up. How can I fix this?
Old 04-18-2015, 03:48 PM
LS1Tech Administrator
RPM WS6's Avatar
Received 1,460 Likes on 1,053 Posts
As mentioned above, only the SES will cause a fail since this is a MIL that represents a Type A or Type B (emissions related) fault. Those other lights have nothing to do with emissions.
Quick Reply: IL emissions
