Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
aluminium flywheel
Old 10-28-2004, 11:54 PM
CNTLSE 1's Avatar
Default aluminium flywheel
I was wanting to check the results everybody got from aluminum flywheels. More specifically fidanza. Worth it or not?
Old 10-29-2004, 07:08 AM
Harley-Davidson88's Avatar
Do a search. I remember reading up on it before and I believe the consensus was that it wasn't worth it.
Old 10-29-2004, 11:33 AM
Sweet Cheeks
Damage Inc.'s Avatar
It's nice to have in an M6, but not worth any measurable ET gains I don't think. Maybe .05 in the quarter. It'll rev quicker and refuce rotating weight, which is a plus. Other than that you'll lose some "off the line" thrust due to the lowered inertia.
Old 10-29-2004, 06:28 PM
CNTLSE 1's Avatar
is there a better flywheel to go with?
Old 11-08-2004, 09:46 AM
Sweet Cheeks
The Fidanza is a nice piece.
Old 11-08-2004, 09:44 PM
97M6Formula's Avatar
Ive also heard its easier on rotating assembly/pressure on rear main and so on I think it would actually hurt your et from lack of mass when you engage it....just something I heard
Old 11-17-2004, 09:53 PM
DrivenWS6's Avatar
Fidanza's are nice. I dont know what the do exactly on the LS1 but on my other car i have a 9# Fidanza and its awesome. After you get used to dirving it its sweet. It revs a lot quicker and you feel the most snap in 1st and 2nd gear. It takes a lot to learn how ot launch a car with a flywheel that light. You have to be very careful for wheelhop. It takes more feathering the clutch. But overall i think that are a good mod. Your not going to gain major time with one but they are fun.Especially in 1st.
Old 11-18-2004, 02:21 AM
CNTLSE 1's Avatar
It is getting installed around Thanksgiving and I will be home over Christmas to drive it so I will post to let everybody know what I think.
Old 11-18-2004, 03:15 AM
dug
dug's Avatar
Id like to try one with 4.33 gears and some sticky tires. Sounds like it would be fun to drive with a car with a lot of gear.
Old 11-18-2004, 12:56 PM
BADSZ28's Avatar
They are a great road piece, but not for drag. With less inertia you will have to launch harder and feather the clutch. This will cause the clutch to go early. Not to mention chatter. If you are planning on dragging it, go with a steel piece.
Quick Reply: aluminium flywheel
