10 Bolt rear SLP Radiator
I will be in St Charles, Il Area this weekend. If somebody is serious, I can bring them with me. Typically in North Twin cities area.
SLP Extra capacity Radiator. Less than 2k miles. Great shape, fits with no modifications. It is for an auto, but will work for manual also. Keeps engine cooler, Slp claims almost 50% more core area. Listed for 1998-1999, not sure what makes 2000 and up different. Still have box it shipped in. New $300 sell for $195
4th gen Rear 3 series ABS. Low miles (< 2k) Eaton Posi, and 3.73 gears. Has Bmr lower control arm brackets welded on. I had this unit sand blasted, and painted last year. Has an Aluminum cover with bearing supports. Also has hooks welded on back of LCA mounts for easy tie down on a trailer. This is a 10 bolt, but if you have an auto, I don't think a 12 bolt is necessary unless you have big power (over 600 hp) I went 1.60 with this unit, and has no signs of problems. Parts alone would cost almost $900 new. $500
Any questions, Just ask.
'J
'J
