Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
FS: Forged LS1 Shortblock
Old 10-25-2006, 04:43 PM
99SLOWC5's Avatar
Default FS: Forged LS1 Shortblock
99 LS1 Forged Shortblock.
30,000 miles pre rebuild
This motor has little under 1000 miles on it, since the rebuild. Oil has been changed twice, Everythings good, no issues, good oil pressure, Correct compression.
1999 LS1 block
Completely dis-assembled and hot tanked
Only bearings not replaced were the cam bearings, as they were fine
New Clevite Rod bearings
New Clevite Main bearings
Stock main caps
ARP Main studs
ARP rods bolts
ARP Head studs
Mahle Forged pistons 4cc Valve relief
Mahle Rings filed for large nitrous 200+
Eagle H-beam rods
TSP ported oil pump
Rollmaster hardened Double roller timing chain
Pistons and rods were balanced
Crank was polished and oil holes chamfered
Looking for $2750
I’ll include my cam if interested, price will be adjusted accordingly
TSP 233/239 .600/.605 112 LSA
JEFF
Old 10-25-2006, 05:51 PM
99SLOWC5's Avatar
figured some might want some pictures
Old 10-26-2006, 09:21 AM
speed disease's Avatar
Does come with heads ready to put in a car and run? I am looking for somwthing complete ready to put in. How much you asking?
Old 10-26-2006, 09:26 AM
99SLOWC5's Avatar
The heads are #853 castings. I saw no lack of HP, I went 11.45@118 in an auto full weight vette with cam only. headers, stall, gears, slicks, tune.
I could do $3450 split shipping
That would be the 233/239 v2. cam TSP, the heads and PRC spring kit, without the rockers and oil pan
JEFF
Old 11-05-2006, 08:56 PM
CLOKWRK's Avatar
Where are you located? Who built it?
Old 11-06-2006, 12:07 AM
99SLOWC5's Avatar
located in south eastern wisconsin. I assembled the motor
JEFF
Old 11-10-2006, 06:33 PM
LS1Formulation's Avatar
If you'd be interested in selling the cam separately, I'm interested.
