Route 66 test and tune tomorrow?
I'm thinking about going out for my 1st time of the season to make some passes before the weather starts getting too hot. Anyone else going out there 2morrow??
what do u guys think of the track prep over there. i have quite a bit of susp. work and ill be running et streets. I know it gets ***** packed there alot and i want to get in more than 3 runs but i want to make them all count. no screw ups.
any personal prep i should do or things i should be ready for??
Retired Street Racer
I would make sure your pinion angle, shocks, tire pressure, etc are set to where they should be. That will limit the amount of passes and time it takes between runs. The staging lanes get quite packed fairly early.
I would also like to make it there by next Tuesday. I have to get a coolant overflow can Matt: How long of studs do I have to order to be able to run my draglites at Route 66?
I cutt a 1.29 60ft there. Prep is O.K
If you have a 10 bolt, I would suggest slipping it off of the line. A 10 bolt can't handle many hard launches, ask me how I know. You just may have to let it cool for a little while between runs. But with Route 66 that usually isn't a problem
yea stocker 10 in there!!!
Originally Posted by litle8
How do you know
With slipping the clutch you'll just end up heating it up a bit. If you hot lap it, you may have issues with it slipping.
2 10 bolts later and I now have a moser 9", much gooder.
Pulled some 1.45 -1.48 60fts last night on a 10 bolt,dont see what the problem is Got a 12 bolt going in real soon though dont want a suprise at the track one day.
Originally Posted by Matt D
Hmmmm, I went 10.85 @ 126 with a stock 10 bolt, consistently. But I had a big stalled auto. Never had to worry about slipping the clutch or launching too high. Just stall up to 3500, and flash the rest of the way.
a drivetrain and suspension after a high rpm dump
